mferris72
I have a Kohler urinal I'm trying to install and am having problems installing the spud for the flush valve. The hole in the top measures 1-5/8". I have is a 1-1/2" x 3/4"" spud. it will not tighten down without bottoming out and pops out. I do not see one bigger available. What size do I need? Should it support the weight of the valve without mounting the pipe for support? I'm also having trouble getting the nut to hold the 3/4"tube for the valve. Came with a blue seal and fiber washer. Bottoms out before it's tight. any help would be appreciated.
