Hello Doug & Others!
Copper sulfate works great if done properly.
We had a root problem from either one neighbor's elm tree (likely) or the other neighbor's maple trees galore. (Unlikely- Maple roots grow shallow.) We're on clay, so the trees must search for water. Sewers are a good source.
Our sewer would clog, so I'd have to snake it every 3 - 4 weeks in summer & winter and once in fall & spring. Each time, lots roots came back on the cutter.
First Treatment:
I started by snaking three passes- until no ore roots returned on the cutter. Then I waited one week for root hairs to arrive in the pipe.
Next, I put two tablespoons of 97% pure copper sulfate crystals in a workshop sink filled with about 3 gallons of water. I let the water drain as quickly as possible by removing the stopper. (A washing machine stand pipe is a good candidate for a fast drain.) We want the crystals to wash down quickly with about 3 gallons of water so that they are suspended and will cling to the root hairs.
Results:
I repeat the two tablespoons treatment every 6 - 8 weeks and I have not snaked in several years. The trees are healthy and brilliant.
Hints:
A) Snake first, then wait about a week for hairs to return to the pipe. Copper sulfate won't eat the big roots, it simply clings to the root hairs, shrivels them & makes them die back away from the pipes so they fall off, to be washed away.
When I was young and worked for a plumbing company, we'd do replacements and find that the roots were dead 8 or 10 feet from the pipe.
B) You don't need a lot of crystals. Commercial root-killo products are either diluted crystals or they are are simply up-selling. It can be hard on this earth, so use as little as possible.
C) Do this treatment when water won't be used for several hours. Evening before everyone retires for the day is a good time, as is morning when everyone leaves for the day. It won't harm the pipes. (Actually, any galvanized or cast iron pipe will eventually develp a copper coating inside.)
D) Keep the extra crystals dry or they will absorb moisture from the air & clump up. Put them in a zip-to-close bag and put the bag in a tightly sealed jar or paint can.
A Good Copper Sulfate Source:
Mindy Materials sells copper sulfate crystals that are 99 or more percent pure. They are far less expensive than the 40% crystals I saw in a home/hardware store. When last I bought, it was about $15.00 for 5 lbs (more than a lifetime supply for root killing). There are many other laboratory supply houses that also sell it & may be even cheaper.
Why We Did Not (Yet) Fix This:
Our building drain & sewer are clay tile and are under the driveway; therefore replacing or lining the clay pipes is something that will wait until it must be done- most likely when the pipe shifts or the snake hangs up.
Moving it is equally challenging, as there would be counters & machine tools to move, plus 20 feet of basement to saw-cut. Once outside, there is a concrete porch 4 feet tall & 8 feet wide to go under.
What To Do With All The Extra Copper Sulfate:
Although it should be used with discretion due to its potential to damage the ground water and fish killing ability, copper sulfate has many more uses. Keep it away from bird baths. It will kill the beneficial, pollinating insects that drink there.
Mix some in water until it is a saturated solution. Squirt it in pavement joints & cracks on a dry day. Nothing will grow there for years.
Mixed properly, it is a good nutrient for vegetable & flower plants. It'll also kill insects that eat the leaves. But be SURE to mix properly. It also kills plants if it's too concentrated.
Mix a saturated solution (Saturated Solution = No more will dissolve). Spray it on wood. The wood will not rot and will not grow fungus.
On the roof, it will kill algae & moss. On pavers, too. (But it can stain the light colored concrete & clay products blue.) My neighbor's maple trees are huge & shade two of my roofs. Algae & moss were eating my shingles. I shot them with copper sulfate. In a few days, the growth was dead & I gently swept it off. Next, I put a strip of bare copper wire on the roof, from gable to gable, just under the ridge shingles. No more moss or algae has grown for many years.
Squirt a very little around the root zone of impossible to kill plants, such as poison ivy and evil grape vines. They'll die. But, nothing will grow there for years. (Shoving a piece of copper wire in the dirt at the plant's stem will do the same thing.)
I killed grape vines that kept returning- even after digging up the roots. (Grapes are very, very toxic to dogs, so the vines had to go.)
For Fun:
In a jar mix copper sulfate crystals in hot water to become a saturated solution. (Saturated Solution = No more will dissolve).
Hook a wire to the positive terminal of a 9 volt battery and to a piece of clean, un-coated metal, like a screw or nail. (Flat strip works well, too) Put that metal in the water.
Clean a quarter thoroughly, removing all oils.
Hook a wire to the negative battery terminal. Hook the negative wire to the quarter with an alligator clip. Stick that in the jar as far from the other metal as possible. Try to keep the alligator clip out of the water.
In a half-hour or so, the quarter will be copper plated & dull. Shine it up & it'll look brilliant.
My truck key & car key look the same. I did this to the truck key. No no more grabbing the wrong key.
I hope your root killing goes well and you can stay clog-free until you can replace or line the piping.
Paul
