What Mitchell-DIY-Guy said about directional boring is a really good plan if you can do the whole job outside. Inside, you'll have to break the floor for the end hole. Unfortunately, my house will still need much concrete broken. As I write this, a contractor for AT&T is outside directional boring from a pit on my front lawn. The other end is more than half a mile away.
I've used directional boring in Detroit & in many states, for installing/replacing miles of both high voltage cables and conduit, as well as parking lot lighting & stuff. New PVC pulls through like a dream- even 6" schedule 80. Sometimes the bore will bounce off a rock or root and get mis-directed, but the boring guys cope well. (The company for which I worked owned machines, so sometimes I was the driver for "easy" jobs. Once, when I was driving, the end popped up in a busy mile road. Screech! Beep! Crash! Oops.)
Spray lining is also a good option if the clay tiles aren't misaligned yet. Once cured, the new liner is as solid & rigid as schedule 40. I've used it on large underground conduits & concrete electrical ducts. It's more popular in Ontario than Michigan, so if you live near Ontario, lots of those companies work on the U. S. side.
I don't know if sleeve lining is good or not. the plumbers here will know for certain.
Hey Paul,
I've got some sump pumps that sit out in a swamp all year till hurricane/rainy season and tend to get clogged with roots, would you dose the sumps with copper sulfate crystals or just put some heavy gauge bare copper wire in the bottom of the sumps? Or both?
Thanks!
A concern about using copper sulfae in the swamp is what will happen to the aquatic wildlife and native plants in the swamp. Also consider the birds who eat the copper laced insects.
It also might be illegal. A landscape company I knew would treat wealthy neighborhoods' ponds with copper sulfate. The company owners went to prison.
If the pumps are in basins, or can go in basins, a permeable barrier made of copper would work. Even if they can be surrounded with dry-stacked cinder blocks, the below will work without doing much damage to the swamp & its residents:
Cover the basins inside with uncoated copper hardware cloth or copper mesh. The mesh will provide a mechanical barrier and leech copper into the roots, but it is more prone to clogging than the hardware cloth. Maybe wrap the pits' outsides with landscape cloth, too.
Watch that you buy pure copper, not copper plated steel. It won't last. Also, be sure it is
not coated. Many are lacquered.
And, I'd be sure to check into the legality & environmental consequences of any copper in a swamp.
I've used both screen & mesh on underground high voltage splice vaults. They are usually concrete and often have an ejector pump in the bottom. Roots would invade through the joints, manhole cover seam & ladder bolts.
Mesh was preferred, but in your situation you want the water to enter the pit, so maybe hardware cloth is a better plan. The only downside was that the water in the bottom of the vaults ended up blue. My boots sure got stained!
