Question about how to plumb main stack
JeffG2583
Dec 12, 2024
Alabama
Hey everyone, I've been browsing for a while, but wanted to ask a question.
Let's say you've got a two story house over a full basement. There's a full bath upstairs and a full and half bath on the main level along with a kitchen. Do you have to run a central stack up from the basement to the attic and tie the upstairs bath to it, then in the basement tie everything else to it before going out to the septic tank, or can you bring that upstairs bath down to the basement then tie everything together before heading out to the septic tank? The upstairs bath would be vented from the lavatory, as would the main level full and half bath. Laundry is also on the main level and could be tied in and vented with the kitchen up through the second level to the attic. The plan was just to tie all the vents together in the attic and take one 2 inch pipe out the roof.
I guess the only difference in these options would be the central stack would then be vented at the top whereas the second method everything would be vented at the fixtures only. Thanks in advance for your help!
You're gonna need more than one 2" vent pipe through the roof. You need to have the same or more vent area as sewer area leaving the building. IE for a 3" sewer you need a 3" vent, or two 2" and one 1 1/2", etc...
OK I will vent the bathroom groups separately and tie the kitchen and washer to one of them. Thanks.
