Hi, 1st post.
The existing plumbing was a worrying mashup of galvanized and copper. No hot in the kitchen, no cold the in the bathroom sink, and the cold in the shower decreasing in pressure, rust stain in the toilet. etc. The house is single wall, raised with the pipes in the crawl space underneath. I decided to go with PEX to bypass the old pipes to return function and safeguard against an emergency repair(pipes had failed in the past.) Everything installed without issue.
I did my homework(tried, anyway) before beginning. I thought my main concern was avoiding direct sunlight. In the evening, the sun hits the back of the house where the system/manifold is currently mounted. I tarped off the area so there is no direct contact with it or the pipes.
Then other opinions started to emerge: no indirect either, and no LEDs. And conflicting opinions.
As it is now, the pipes are entering through the windows, at least until the old pipes can be removed. I was weighing the options of final configuration. but if I ran the pipes under the house where no direct light ever reaches, but it is lit by reflected light, do I need to be concerned? Is ambient UV a thing? Is latex paint an effective solution, any downsides? How about black heat shrink tubing? do I need to to cover/coat the the entire length or a certain distance away from the direct light? I was also thinking of running it thru electrial conduit pipes.
Does it basically need to be in complete darkness?
I did install it knowing that it might be just a stop gap, not that I like to burn money. If there is a chance of getting a good lifespan out of it, I'd like to try.
