Hello, I am trying to figure out everything I need and correct sizing to run a portable generator off of natural gas.
My gas meter is located 70ft from the spot where I would like to have a dual - quick connect valve, one side of the quick connect to plug my portable natural gas generator during emergencies and the other side to plug my Weber Genesis grill.
The manual for my generator has this information:
Natural Gas Feature: 6900 Starting Watts, 5500 Running Watts; 439cc engine.
Natural Gas Pressure Range: 7-11 inches water column (0.25-0.40 psi) (13-20mm mercury) (1.7-2.7 kpa)
Natural Gas Fuel Consumption: No Load = 72 cubic feet/hr; Half Load = 86 cubic feet/hr; Full Load 101 cubic feet/hr
My generator has a 3/8th inch male connector on it.
Here are my questions:
What size pipe should I have a plumber run from my meter to the spot with the dual quick connect that will supply a sufficient amount of gas?
What size should the quick connect connectors be?
What size hose should I use from the quick connect to my generator?
Will I need any adapters to going from a larger size to a smaller size?
I am a total novice at all of this so my terminology may be wrong. Try to break it down for me on kindergarten level lol!
Thank you for your help!
