Here is what I have. Well water. Symmons valve that's original in a 44 year old house. No service stops. Diverter has two screws holding back so it's old. Hot water line leaves tank. Goes to tee. One line goes up to the washer 1st floor then up to 2nd to valve. No other fixtures. Other line from tee goes to 3 sink fixtures that are two handle and dish washer. No cross connection, I checked even I believe it happens on single. All fixtures work fine. Hot.Tank is new and problem was evident on old tank toward the last year although not as bad. All pex lines with no changes from original way.
Things I've done so far. As mentioned checked for cross connection including washer. Rebuilt valve. Tried 3 different spindles. All new. Front flushed. Backflushed. Removed valve guts and put airline into hot line, blew 90 lbs of air into it. Rubber tip gun right against hot seat. Before this I took off hot corrugated line of tank and into pail. Wanted to see what came out. Nothing. Shut cold water off and ran hot into emptied valve and got hot water with flow. Tank is set to 140. Said WTF several times. Adjust screw in cap all the out. While tub is running ran cold water in sink to take some of the cold water. No change. Flushed down stairs toilet. Water did get warmer. But after awhile went back. The one thing I didn't try and just thought of while writing this novel is blowing air from hot line from and up to shower valve. Read before it helped somebody.
Things I wonder. Could the valve body especially the cold outlet be worn out. I do get more then Symmons says (I also talked to them) which is a pencil size flow on the diverter.
Thanks in advance for any help or even taking the time to read this
