Leak at base of toilet (brown water) - wax ring failure?
pakle
Dec 27, 2020
198
52
WA state
UPDATE: Leak due to wax ring that shifted slightly
I found a slight leak at the base of the toilet that I almost missed. No visible water except for a small shiny spot at the back, and then I used paper towel to confirm it's water (virtually undetectable otherwise). The base is not caulked. No leak at the hose connections and I don't think there's a toilet crack. Water is brown and slightly more in the back. Seems to be water all around. The attached pictures are the paper towels left overnight. The 'wetness amount' change very little overnight, possibly because the toilet was not used at night. The stained areas are also no longer 'wet' now so maybe it only leaks when the toilet is used?? The toilet (AS Cadet 3) was last replaced during a bathroom remodel about 8 yrs ago with an extra-thick wax ring by a plumber.
I'm thinking brown water indicates wax ring failure?? What do you all think? While I'm calling plumbers to see who can get out here to pull the toilet. It's a guest toilet (2nd floor) so not a big hurry. Nothing leaking down to the 1st floor yet, the floor isn't mushy, and the toilet position seems solid.
PS. Should I shut off the water? Not going to use the toilet.
Thanks all!
    1.6 MB
    1.4 MB
Cold be a wax ring ,check the water connections and also the tank to bowl bolts,look on the underside of the tank you will see brass nuts and bolts
Have you wiggled the toilet to see if it's loose
Dry up the floor and flush a bunch of times to see if you get water around the base
Seems like an easy wax ring replacement. It wouldn't hurt to shut off the angle stop valve if you don't plan on using the toilet until a plumber or handyman can replace it. It is quite simple, but they can be awkward to lift off without making your back sore.
Thanks guys! I was able to get a plumber out today and he said the wax ring had shifted slightly. There wasn't even any water around when he pulled the toilet (see picture), it had all dried up from last night. The leak so slight so it did not damage the subfloor.
He used the 2 waxes and hoping this seal lasts longer than the old one! He offered to caulk the base leaving a gap in the back, and I said no thanks. $450+tax but at least it's done right and I'm relieved there's no damage.
PS. I suspect the cause was when the tank had a hairline crack several years ago (I wrote about it here), and we replaced it ourselves. There might have been some 'extra movement' of the toilet to get the new tank in that possibly shifted the wax.
    1.7 MB
Maybe. Go under the house and check there. Even if the wood isn't coming apart there might be mold that should be treated.
Toilet is on the 2nd floor and there's nothing showing on the ceiling of the 1st floor. Plumber said it's clear that whatever little water that seeped just flowed out the sides. He's sure the subfloor is not damaged so not going to open up the ceiling to check.
Update: Still leaking 24 hrs later... see brown water on paper towels I have lined all around the base (less than before though). Not detectable otherwise and takes hours to show up. The plumbing company owner will be stopping by Monday. Plumbing woes continue...
Call them back and have them repair it for free. This time, have the guy caulk the 3 sides of the toilet and do not use the toilet until it dries.
You sit, you break the wax seal, and you will start from square # 1.
Just for clarification, it's the caulk that provides the stability and not the installation of the toilet itself?
Snug bolts and shims make the toilet stable. If you have rough or heavy arses, you will push the toilet lateral very quick without caulking to secure it.
Skinny arse kids can also slam their butts and shift the toilet.
My kids destroyed a section of the couch by always dropping onto it like they were trying to emulate a pile driver. The webbing underneath tore apart and the springs fell over. Flipped the couch over and reoriented the springs, tied them together properly, and redid the webbing. A year later they had destroyed it again in exactly the same place and way, but this time they had also beaten down the front of the couch. I have no idea how to fix that front piece. They went off to college and the couch destruction ended. Then after college they returned and the couch torturing resumed. My daughter eventually moved away, but my son is still here, and he now has more than 200 pounds with which to mash the furniture. He still sits in the same place despite it now being a hole much lower than the rest of cushions. If I sit there I can barely get up again, it's like sitting in a big cushioned bucket.
Despite their couch destroying proclivities, they did not destroy the toilet.
Thanks all, yes the Owner says he's coming back under warranty. Will have him check the floor more carefully, I've put a level there as a reminder. It's a guest toilet and sparingly used, usually by adult females under 110 lbs but you never know. I'll ask if caulk is necessary, prefer not to have it because it makes the paper towel leak detection more difficult and my other 2 toilets are fine without caulk, but will defer to his opinion. I hate caulk but I hate brown water leaking even more lol.
@havasu How do I edit my original post? It let me edit once but not anymore.
We have a time limit of editing, which you have reached. Feel free to let me know what to add or delete in a private conversation. Simply double click my avatar and click on the conversation tab.
What does the code say in your area? I'm not an expert, but a little Google-fu suggests that it is common for the plumbing code to require the toilet be caulked.
I think the pro-caulk argument is more or less as follows. If the toilet is bolted down and caulked it is unlikely to move so a wax seal leak is unlikely - but water seeping underneath from a tub or sink overflowing, or the toilet itself overflowing, or a supply line rupture, is more likely. If the toilet is not caulked that water would seep underneath and then soak into the floor in a location you could not see.
The preceding argument would suggest that toilets should have a little hatch somewhere above the base with a rubber cover so that if a leak is suspected one could pop the cover and have a look. However, I'm not aware of any toilets that have this feature.
By not caulking the rear of the toilet redolves this issue. If you see any leaking, you know your wax seal is broken. It also helps to clean urine down the front of the toilet, making the bathroom more sanitary.
