Bangon61
My Rheem hot water tank wasn't producing hot water. Took the cover off top element and found this burned wire. It's a closed loop system that heats a small floor area. Couple questions. Is it because I hadn't fully filled the tank? Should i just replace element or element as well as thermostat? Thank you
