No. That is a double flare tool, and you need a single flare tool for that copper line.
Thank you!For 1/2” of tube you use 1/2” flare setting.
The flaring tool you posted will work, just use the single flare, no adapters needed. That tool will do both double/single.
Older tube can be hard to flare with those cheap flaring tools.
Hahaha, you came here. You are playing with gas, have no idea what you're doing, asked for advice, it was given, and now you decide that it's OK to be an ******* and still expect help. You probably don't even know what type of system you have.Thanks for false information.
No sir! One person told me that the flare kit I have pictured wouldn’t work, another said yes it would work fine. I tried to reply to the person that said it wouldn’t work. I’m new to forums and I guess I messed up. I DID thank the person that gave me the answer to the question I asked. I wasn’t being a ***hole! I’m sorry if I offended you.Hahaha, you came here. You are playing with gas, have no idea what you're doing, asked for advice, it was given, and now you decide that it's OK to be an ******* and still expect help. You probably don't even know what type of system you have.
I may have overreacted a bit. seemed to me like you were being ungrateful since the post you were trying to reply to was not quoted, and the message was very sarcastic so pretty easy to take as you being a bit of a jerk... MicEd was not wrong, but may not have realized that it could do both styles. Glad your project is done. I am curious, it looks like you might be on a high pressure setup. Do you have to have regulators at each appliance? What were you adding the line for?No sir! One person told me that the flare kit I have pictured wouldn’t work, another said yes it would work fine. I tried to reply to the person that said it wouldn’t work. I’m new to forums and I guess I messed up. I DID thank the person that gave me the answer to the question I asked. I wasn’t being a ***hole! I’m sorry if I offended you.
Oh, and the job I was asking about is done, and operational without leaks. So I guess I know a little more than you thought I did.
I apologize profusely. I have dedicated flare tools and have never used my double flare tool for a single flare. But as Twowaxhack said, it can be done.Thanks for false information.
We live in a mobile home and where we are we get a lot of severe storms, and we occasionally get ice storms and lose power. I installed a wall heater as a backup so we would have heat if we lost power. I’m a retired house painter and have minimal plumbing and electrical experience .I may have overreacted a bit. seemed to me like you were being ungrateful since the post you were trying to reply to was not quoted, and the message was very sarcastic so pretty easy to take as you being a bit of a jerk... MicEd was not wrong, but may not have realized that it could do both styles. Glad your project is done. I am curious, it looks like you might be on a high pressure setup. Do you have to have regulators at each appliance? What were you adding the line for?
I too am glad your job is done, but it is a little disconcerting when someone who doesn't know about gas lines work on them.Oh, and the job I was asking about is done, and operational without leaks. So I guess I know a little more than you thought I did.
The picture of the meter is how it was hooked up by the gas company when the gas was hooked up when the mobile home was set on my property 20 years ago and hasn’t been touched since. lol this is Alabama and the gas company sees it every month when they read the meter. I spliced into the line under the mobile home.I too am glad your job is done, but it is a little disconcerting when someone who doesn't know about gas lines work on them.
As Twowaxhack said, it does appear they may be Teflon tape on a flare joint that isn't required and can be problematic.
Also, there is a reducing bushing in your picture that is illegal for use in gas piping.
You may not have installed these items shown in your picture, but if you followed these examples, you may have installed some non-code items that may be dangerous.
It’s still improper, I don’t care who did it or when and the flunkies that read your meter don’t care and probably don’t know.The picture of the meter is how it was hooked up by the gas company when the gas was hooked up when the mobile home was set on my property 20 years ago and hasn’t been touched since. lol this is Alabama and the gas company sees it every month when they read the meter. I spliced into the line under the mobile home.
My wife told me an employee of Northwest Alabama Gas District came and inspected it and checked for leaks before it was used and gave he the ok.It’s still improper, I don’t care who did it or when and the flunkies that read your meter don’t care and probably don’t know.
Roll tide.
Oh I don’t do roll tide, I’m originally from Lancing Michigan, GO BLUE!
