Hi, I’m using the MQ3-45 on a 3/4” main with City Water. It works great so far; except that when it kicks in the inlet pressure gauge, drops all the way down for a split second and the pipes jerk. Would a vacu-arrest: Vacu-Rester 1/2" MIP Vacuum Breaker Water Hammer Arrestor eliminate this issue? There is no lag or decrease in water flow when this happens. I’m concerned about the supply connections which are buried behind a gas fireplace. I know this was not a smart thing to do. My supply pressure is about 45 psi (a little high) and I will probably add a regulator as I did for the output. I keep the pressure at about 65psi. Any suggestions would be greatly appreciated. Been using the pump for six months for house and irrigation. No issues except for the thud
